Visibility of Surface Pattern in realistic view
I have applied model surface pattern to wall.
The surface pattern is shown when visibility is in shaded or wireframe mode but the pattern visibility is off when kept in realistic view.
How do i make settings so that i can see the pattern in realistic view?
PFA- Screenshot's of shaded and realistic views
Thanks in advance!
Realistic and raytraced views are governed by the material's appearance tab.
Thank you for the quick reply!
Can you please brief me out the procedure to to view model surface pattern in realistic view?
Thanks 2 Answer
Kimtaurus
It's not possible.
The material's appearance in Realistic view is defined by the Appearance tab. Hence the name "Realistic View".
The surface pattern (fill pattern) is only visible in Hidden Line and Shaded View (and maybe Consistent Colors as well, not sure).
If you want a texture in Realistic view, you'll have to create a new appearance asset and set an image.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Alfredo_Medina
Find a photograph of the material, as .jpg, and add the .jpg file to the properties of the material.
Viveka_CD
Thank you @Alfredo_Medina
@Anonymous  Also see article on Changing the Appearance Properties of a Material
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Material Asset: "Shake-Handsplit"
