Revit project to vr?
Message 1 of 8
Can someone help me as to the easiest/best way to transfer a completed revit project to a phone app, for walkthroughs using simple google cardboards?
Please let me know
Replies (7)
Message 2 of 8
amorap
Hello from Spain trentFWC8V
I have not tried (yet) it, but Twinmotion 2018 is capable to generate an interactive model to be viewed in a HTC Vive, Oculus Rift or Samsung VR devices.
Also, there are a plugin for revit to direct synchronize the model in Revit with Twinmotion.
Regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Message 3 of 8
L.Maas
Not easy. Transferring a project in such a way that it will run as walkthrough on a mobile phone.
I have used Unity for this. However it is not simple. It requires quite some work to get the Revit project ready.
Unity can create projects for Android, iPhone and browsers.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 4 of 8
DarrenP
please see your other thread on this subject: https://forums.autodesk.com/t5/revit-live-forum/export-revit-to-google-cardboard-fully-interactive/t...
DarrenP
Message 5 of 8
JGallagherP3A
Here's a basic tutorial going from Revit to UE4: Revit 2017 To Unreal Engine 4 Tutorial With ScreenShots
Once it is in UE4 you will be able to package your product for Google Cardboard.
Message 6 of 8
Viveka_CD
Hi @Anonymous
Please see the information HERE to use VR with Revit Live
See an AU class for Revit to google cardboard HERE
Similar post HERE
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome
Message 7 of 8
DanReu
Do you have to be able to walk through? You can render static 360 stereo panoramic images from 'Render in the Cloud' menu which provide a great immersive view of a project quickly with no additional software required.
Message 8 of 8
yurikim
Hi @Anonymous
I would suggest the same as @Viveka_CD. You could try out the trial first and see if this works for you.
If you need anything further, feel free to PM me.
Cheers,
Yuri Kim
Product Support Specialist, AEC
