let's say I draw stairs from ground to first level ... why i see treads which covered by floors in level 1 shown in screenshot
If you know how to hide it tell me please ?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If there is a floor covering the stair then you should not see it. So you actually have a floor there? Is the view wireframe?
Is the floor visible and not transparent in the view? Can you actually select the floor?
yes i can select it and it's solid i know it's weird !!!!
Not in the 3D view, I meant for you to select it and check it in that particular floor plan. The floor maybe hidden or transparent in the View.
