Solved by michael.freeman2T5SF2. Go to Solution.
I am having the exact same issue. Has there been any solution to this? I tried it on another PC and although it printed (to PDF) 2 out of the 3 drawings, the last one failed. Then the message appeared. I am currently using Revit LT 2020 and on my colleagues computer, it was on LT 2021.
I think this might not be a Revit issue, but a printer issue in general. There are a couple articles related to Adobe with the same error. Might be useful to try some of these solutions:
We started having the same issue at the company with one user. And now with two users as another person was asked to PDF some sheets.
Getting exactly the same behaviour as mentioned by @michael.freeman2T5SF2
Hi I am getting the same error on RVT 2020. What's worse is that when I try to print anything from Adobe Acrobat, I get the same error. My coworker tried to export sheets from the same model on his computer and is also having this issue now. When we open the printers & scanners page under settings, all of our printers are marked as "not connected". Does anyone have any ideas or suggestions?
I have managed to find the cause and solution. If the Printer Spooler has stopped working and its not able to restart, follow the below and hopefully this should fix your problem:
