Revit print to PDF rotates the file, or rotates all files after the first sheet
PaulLankenau
PaulLankenau
Revit print to PDF rotates the file 90 degrees, or rotates all files 90 degrees after the first sheet of the set which prints fine. This only happens with my 11x17 sheet size. No problems with my 24x36 sheet size. I have tried many different settings but don't know if this is a Revit problem or my PDF Creator problem. I updated the PDF program, but the result is the same.
Autodesk, Anyone?
dferreira-blackwell
not a Revit problem I think, try to use cute pdf it's free and see if the result is the same.
This is typically a PDF creator problem - it can't be fixed in Revit.  I know that people have had issues with different types of PDF creators.  We use Cute PDF, which is free and we don't have any issues with this (make sure that you un-tick all the extras that come with the download).
smartignago
Community Visitor
Community Visitor
I have the same problem. Using Cute PDF cannot be the only solution. Any Revit based solution?
