Revit parameter
Revit parameter
msdvicky
Revit parameter
msdvicky
I need to create a formula for a parameter in which whatever the value user enters it should return a value in multiplication of 250.for example if the user enters 150 it should return 250 if user enters 600 it should return 750. Any idea on this?
TripleM-Dev.net
Use 2 parameters, a input parameter and a converted parameter and use the function Round / RoundUp / RoundDown.
See samples below, depending on rounding demand use any of the 3 rounding functions.
(looks like you need Roundup, 0=250, 600=750 etc)
For this example I used Integers, but could be used with any number units.
Round, RoundUp, RoundDownRound, RoundUp, RoundDown
- Michel
Preparing client invoices?
..if so, whatever you do, don't put a stamp on the envelope and mail the invoice.
If there is one thing I learned from watching the movie "The Firm"; the stamp is what makes the False Invoice a Federal Crime - not the False Invoice itself.
FWIW
msdvicky
No! its just a component height which should increase by 250 mm.thanks
msdvicky
Thanks!!
