revit organic families
Message 1 of 17
Iam learning revit, I am practicing right now with families.
Mostly all of the families are boxes or squares or circles but not organic.
Can I design in revit organic families? How? Is it possible?
Replies (16)
Message 2 of 17
aRcHiTeCt.JM
…. Hi @Anonymous
…. Of course you can do organic things in REVIT
…. What do you want to make/design?
….. you can create families with the CONCEPTUAL MASS
….. almost any shape you can imagine
…. Or you can create families with forms and voids, etc…
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 17
yeah yeah but how??
Message 4 of 17
GHASEM_ARIYANI
Hello @Anonymous
Revit is very powerful, But I suggest you use DYNAMO for organic designs.
I put some Revit tutorials on the link below
Revit tutorials
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Message 5 of 17
aRcHiTeCt.JM
 .... @Anonymous
…. Let me show / teach you one quickly
…. Let’s make an APPLE
… open a new family
… you can use metric generic model (i'm using it)
…. Save it as : APPLE  .... or whatever you want it
… go to front elevation
… draw a reference plan (more or less .10 cms)
… and click in revolve
….. click in spline
…. Draw this shape between the ref. planes
… and after that click in axis line and draw it from point to point (blue line in picture)
(.... and another straight line to close the gap behind the axis line)
….. click finish edit mode
…. Go to 3dview
…. There you go, you have your own organic apple
…. Just apply a texture (anyone- I just used green color )
*** … and with the swept blend you can create the little piece on top
… you can play with this, rotate, copy-paste more and change colors, etc…
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 6 of 17
aRcHiTeCt.JM
.... @Anonymous
…. Attached my apple family .rfa
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 7 of 17
@GHASEM_ARIYANI thanks for your answer, i will try to go through all of those videos. scary. too much. kkkkk Smiley LOL
I am just learning but these are great
Message 8 of 17
@aRcHiTeCt.JM thanks this is great. simple but that is what Iam looiking for. do you have more like this?
Message 9 of 17
GHASEM_ARIYANI
Smiley Very Happy
There are also very strong tutorials on the blog below
Be sure to read
Andy Milburn
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 10 of 17
Do a search for building freeform in revit on YouTube. Ton of tutorial on using conceptual mass and adaptive components. Good luck, no actually you don't need lucks, you just need patience and practices.
Message 11 of 17
What to see something that will blow your mind?  Marcello Sgambelluri's Revit Elephant. 100% Revit-made.
https://www.youtube.com/watch?v=aJWigOn_Gt8
Google Marcello Sgambelluri's Revit Cow  and Marcello Sgambelluri's  Revit Human Head  for other mind-blowing examples.
Message 12 of 17
syman2000
Hi there,
I also ponder the same question. I try it and see if I am able to create anything within Revit and result is yes you can build anything. The method used are spline thru points and have lots of patience. See example below.
Mario Bros.Mario Bros.GokuGoku
Elsa from FrozenElsa from FrozenDeloreanDelorean
Message 13 of 17
Lehainam1
Observer
Observer
I can't export texture of elsa to fit in family revit, u can explain in this, thanks!
Message 14 of 17
syman2000
The Elsa I've built is native Revit. So I like to know what issue you are having with.
Message 15 of 17
Lehainam1
Observer
Observer
I export sketchup file to revit but the texture is like a "http://www.mediafire.com/view/ybwon4ycva4ovc5/elsabody_d.bmp/file", and it's not fit in to revit family!
are u have a resolusion to this, thanks!
Message 16 of 17
syman2000
You cannot use the sketchup texture map. If you want the model to use as a family, you have to break up the model into layers. Then manually map the texture to layers.
Message 17 of 17
syman2000
@Lehainam1  you can download the Elsa I've built from this website
https://market.bimsmith.com/product/BIMsmith-Generics/revit-bim-Elsa-Frozen-46315
