Revit on Mac M1
Revit on Mac M1
n11270373
Revit on Mac M1
n11270373
Hi there,
I am about to buy a new laptop and I am looking at two options:
-Dell XPS 15'
-Apple Macbook pro 14'
I would like to know if anyone using an M1 or M2 chip have been having any issues with Parallels and Revit.
I am leaning to get an Macbook pro because its hardware. I always used Windows, and I feel that Windows computers dont last as long as an Apple. Plus, I used to like to do anything I wanted on a Window 7, and now a days Windows are as restricted as an macOS.
DarrenP
do you have an example?
lots of threads on this subject i recommend reading through them: https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&...
Revit will always be a Windows OS exclusive it will not take advantage of any of the Apple hardware since its never been developed for Apple hardware
DarrenP
mhiserZFHXS
If you're using Revit, just go Windows. Why deal with the hassle of Apple?
ola6n4qrvdsr
Revit on Mac hardware has been a long-desired option.
The prospect of the M1/M2 hardware's performance is appealing, and you don't need to buy an expensive workstation card on top of the system cost to get smooth, slick computing on OSX:  https://www.macrumors.com/review/macbook-pro-m2-pro-m2-max/
The problem is Windows applications don't run on OSX, so you have to run some additional virtualisation software that makes the Mac chips run a 'virtual' Intel x86-based hardware that Windows will support. The options are Bootcamp which is a dual-boot system or Parallels.
Bootcamp works pretty well in some respects, but you can't run Windows and Mac applications side-by-side, and more importantly doesn't allow you to install Windows 11, only earlier versions and will have ongoing future issues with software compatibility going forward, as Autodesk and other software gets updates.
Parallels run inside OSX, so you can run Mac and Windows applications side-by-side.  However, the software Parallels uses to emulate the hardware has no access to the Mac's device's physical graphics cards. Instead, Parallels Display Adapter driver interfaces with virtual hardware, actual acceleration is achieved by translating Direct X commands from the guest OS to the OpenGL API on the macOS side.  In short, Mac desktop standalone graphics card, known as "discrete graphics" (if you have one) or the M1/M2 GPU graphics chips (if you have those) can't be used by the Windows applications.  The graphics and 3D acceleration are all done by CPU cores, a performance layer which is much slower than a cheap entry level graphics card would be.  For basic Windows applications like Word or Excel, you probably wouldn't see much difference, but for a graphics-heavy program like Revit, the performance hit is often very obvious if you're accustomed to using Windows native computer hardware.
If your heart is set on a Mac M1/M2/Mx computer, just stick to native software that runs directly on OSX, don't waste your money -- or buy a good Windows computer instead.
bewivobsrea
Community Visitor
Community Visitor
Hey, Parallels runs on M1 and M2 Macs, but Revit isn’t natively supported on macOS and can have some performance or compatibility issues running through Parallels. When considering m1 vs m2 MacBook Air performance, the M2 offers better speed and efficiency, which can help with virtualization tasks like Parallels. The MacBook Pro has excellent hardware and longevity, but if you need full native Revit support, a Windows laptop like the Dell XPS may be more reliable.
