REVIT MULTIPLE IF CONDITIONS WITH 3 PARAMETERS
3646297NWX
Message 1 of 14
3646297NWX
Hi Everyone,
I wanted to create a formula with 3 visibility parameters and it would only allow the selection of one item at a time (deselecting the others).
For example,
If Attention Checked, not (OK) not (Pending)
If OK Checked, not (Attention) not (Pending)
If Pending Checked not (OK) not (Attention )
try this, but not work for me.
https://www.autodesk.com/br/support/technical/article/caas/sfdcarticles/sfdcarticles/PTB/Set-yesno-f...
Any help or suggestions will be appreciated.
Thanks in advance.
Replies (13)
Message 2 of 14
RC_RVT
So you need 3 yes/no parameter that can be adjusted like you have. These are not assigned to anything because they could be done wrong by the user.
You then have 3 yes/no parameters, (attention_, ok_, pending_) that are assigned or are essentially the correct/working parameters, if that makes sense.
You cannot use your formulas you have put in.
Use the following formulas for each parameter you have:
Attention = and(not(OK),not(Pending))
OK = leave empty as you have done
Pending = leave empty as you have done
attention_ = Attention
ok_ = and(OK,not(Pending))
pending_ = and(Pending,not(OK))
Message 3 of 14
3646297NWX
It didn't work. The user is able to select two options at the same time (OK and Pending). Only one option can be selected at a time (Attention, OK, or Pending).
Message 4 of 14
3646297NWX
Message 5 of 14
Your formulas are running in circle.  For more than 2 parameters, use Integer instead of Yes/No.
1 = attention
2 = ok
3 = pending
Message 6 of 14
RC_RVT
Yes, like I said these are the face value options, in the background the "actual" yes/no parameters will control this as they will only turn on if the correct boxes are ticked. I don't know what you are using these for, but I use them all the time in families I create, and yes you can select the wrong boxes, but the background parameters keep this all controlled. If you are only using this for selection purpose and it's not controlling a family, use an Integer as ToanDN has said.
if you want to use these parameters as you have shown, use the following which I have adjusted:
Attention = attention_
attention_ = and(not(ok_),not(pending_))
The attention_, ok_ & pending_ parameters will control the model so that if both OK & Pending are ticked, as you have said, attention_ & Attention will automatically tick therefore highlighting that there is an issue.
Message 7 of 14
RC_RVT
See above video, I have also created an Alert text parameter that displays text if there is a change required.
ALERT = if(Attention, "CHECK OK & PENDING CHECK BOXES", "")
Message 8 of 14
3646297NWX
With the code above, the user is able to select 2 items. This should not happen; the status should only be 1 item, just like a radio button in HTML.
Message 9 of 14
azad.Nanva
if i understand well,use this:
Message 10 of 14
RC_RVT
Like we are saying, if you don't want the option to be able to select 2 buttons then use ToanDNs method. There is no possible way for only one button to be selected using the method you were wanting.
"If you are only using this for selection purpose and it's not controlling a family, use an Integer as ToanDN has said."
Message 11 of 14
azad.Nanva
but in my solution is just one button must selected.
Message 12 of 14
RC_RVT
In your solution you can still select both OK and Pending at the same time I believe. This is something that they don't seem to want to be able to do. In my solution it has the same outcome as yours.
Message 13 of 14
nozci
This can't be done more than two parameters. Basically, what you want is radio buttons but this requires a parent class controlling checking status of the buttons like 1 2 3 which brings you to Toan's solution.
There is no such mechanism in Revit as far as I know, may be internal but not to the user.
Message 14 of 14
TripleM-Dev.net
Like @ToanDN mentioned , if you have mutliple choices and only want user to be able to pick specific combination use a integer parameter which controls the conditions.
So if you have 3 conditions (or more..),  use:
Option_selection (integer, also add a tooltip desc. the values)
Condition 1 = or(Option_selection = 1, Option_selection = 2)
Condition 2 = or(Option_selection = 2, Option_selection = 3)
Condition 3 = or(Option_selection = 3, Option_selection = 1)
Condition 4 = or(Option_selection < 1, Option_selection > 3) <= I also always include a default or alternative it none of the valid values is entered.
Bonus for this, it's scalable, with a bunch of Yes/No parameters it's going to be a mess to edit something later on.
