Revit model elements move to family based workset
I'm stumped on this issue. I've been working in Revit for around 8 years now, I have a newish grad working under me that has 1 year of Revit experience. We keep running into issues where he will work in a model and he causes all model elements to switch to a family-based workset instead of our office standard worksets. For instance, all walls that were on a shell and core workset will now be on a family: xxx-xxx workset.
I've watched how he will start a new project and it's left me clueless as to what is causing this problem.
Steps they are taking:
- Create new project from our template file
- Save file to proper location
- Sets up worksharing by clicking on the collobrate-> worksets
- Sets standard workset up for our company
- Saves file as central file
- exits file
- Creates new local file
- Starts drafting whatever we are doing
We've also had this issue happen when he has gotten into a model that was already created and set up properly. Afterwards everything will end up on a family based workset and our standard worksets disappear.
Anyone have a clue as to what would be causing this?
Sahay_R
Are new objects created on an active workset?
Also, if no one else and no other machine is having this problem, could be a corrupt user profile.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
OrmondAllred
Having similar issues. Any known workaround, or way to move objects to a new workset?
Are you mixing Revit and Revit LT when working with the project?
OrmondAllred
Workaround: cut/paste to current view (while on the proper workset). Not certain why this happens.
OrmondAllred
Full Revit, both users.
