Hi everyone,
I was trying to get a 2015's RVT file to open in Revit 2018, but there is a constant error message talking about corrupt families. Even when I click the "delete families" options the file wont open. I downloaded Revit 2015 and asked for an activation code, so I can try to open the corrupt file in 2015 and delete the problematic families.
Is there anyone that had this issue, i definitely don't know what to do.
This type of question should be asked over in the Revit forum. This forum is about installation and licensing issues of Autodesk products.
Mark Lancaster
& Autodesk Services MarketPlace Provider
No biggie.. Just wanted to make sure you get a solution to your answer and most likely the Revit forum will provide that.
Mark Lancaster
