revit model cannot be cleaned up
zhounnin
Message 1 of 10
zhounnin
i have big model (about 1 GB) downloaded from BIM 360
1) for unknown reason, i cannot open it w/ Audit option
2)  so i open it w/o Audit option, but now i cannot Purge Unused
i'm out of options, anyone encountered similar issue and how to fix it? thanks
Replies (9)
Message 2 of 10
ennujozlagam
dont audit first, detach form central your file? thanks
Message 3 of 10
sureshchotrani
Review the Autodesk Knowledge Network article -
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 4 of 10
zhounnin
thanks sureshchotrani, looks like no easy way out for sure
Message 5 of 10
sureshchotrani
Welcome.
Message 6 of 10
Nadeem_Skets
your element is removed from central model by other user.thats why its not able to do the process
Message 7 of 10
zhounnin
what happens if some families cannot be edited and saved out? seems deleting those families are the only way out? well, i don't understand why family cannot be edited, someone must try very hard to screw up model! is there a way to fix those families?
Message 8 of 10
zhounnin
i uploaded the RVT w/ 2 bad families to see if anyone can fix them and how to fix?
Message 9 of 10
RobDraw
Does it work on BIM 360?
How did you download it?
Are there links that didn't get downloaded?
Rob
Message 10 of 10
zhounnin
thanks Rob, well, I don't think it's related to BIM 360 at all, just poor modeling practice accumulated for long time w/o quality control at all, now I only want to figure out how to fix those 2 families I uploaded here, must have a way to fix it! anyone from factory?
