Revit mark every object then moving the cursor around
oliv420v
Message 1 of 11
oliv420v
It dosent select all object but just mark them. Then i zoom in or out it remove all the marks.
I attach a picture
Replies (10)
Message 2 of 11
RDAOU
@oliv420v
  • Try disabling the following two options
  • Check mouse sensitivity (if mouse driver allows)
  • If the above persists look into buying a new mouse
Message 3 of 11
oliv420v
Thanks for your help, if dosent fix my problem but i  have now find out it only does it in my lector template but not in the other templates....
Message 4 of 11
HVAC-Novice
Check the mouse settings in windows and look if some are weird. Just write "mouse" in the Start bar.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 5 of 11
bradH4N2Z
Observer
Observer
Select the option to disable touchpad when mouse is connected
Message 6 of 11
rusov_zan
Community Visitor
Community Visitor
I have the same problem and I tried all of the suggestions above, but nothing helps. Is there a solution?
Message 7 of 11
FrederikViderup
Community Visitor
Community Visitor
i do have the same problem.. did you find a solution?
Message 8 of 11
JL.FCG
This happens to me, on a daily basis. I'm not sure whether to say if its a graphics problem or not.
I have been doing the same solution as you, as its the only thing that works for me also at the moment.
If you select or scroll your mouse over a element, it acts like you have it still selected when you don't, even if you press ESC or click elsewhere.
The only solution I have for this is zooming in and out slightly. This should show as deselected after zooming.
Message 9 of 11
peg
Go to OPTIONS > GRAPHICS> uncheck "smooth lines with anti aliasing"
that seemed to work for me
Message 10 of 11
Jonatan_Ferrer
Community Visitor
Community Visitor
Without any selection, go to Properties -> Graphics visualization options -> disable anti-aliasing
*see image attached
Message 11 of 11
Ac7FRK5
Observer
Observer
one of my co-workers just had this problem on a new lenovo p16s.
We simultaneously reinstalled Revit and changed the power mode in windows to High performance and the problem is gone.
i dont think the powermode had anything to do with it but just in case.
and it was in revit 2025
