Revit LT
Revit LT
Message 1 of 13
Revit LT
I'm interested in the Revit LT package as it appears to have the capability of saving/exporting Revit files to .IFC format according to https://www.autodesk.co.uk/compare/compare-features/revit-vs-revit-lt?mktvar002=afc_gb_nmpi_ppc&AID=...
However I have downloaded the trial of Revit LT and when i go to File>Export>IFC this option is "greyed" out and wont let me select it. Can you confirm that Revit LT is capable of exporting revit files to IFC format?
Josh
Replies (12)
Message 2 of 13
RobDraw
According to this, it does not.
Rob
Message 3 of 13
Alan.johnson1970
It definitely works in LT 2017.2
AJ.
Message 4 of 13
Thanks Alan
Message 5 of 13
RobDraw
Here is the procedure for exporting to IFC.
Rob
Message 6 of 13
So my company decided to purchase the full Revit package, however when i click File>Export>IFC the option is "greyed" out and wont let me click it, just like when i was using the LT version. Has anyone come across this before?
Message 7 of 13
RobDraw
Please verify that you are following the proper procedure. Saying the same thing does not help progress the trouble shooting.
Rob
Message 8 of 13
I assume i am, I open the .rfa file that i want to convert to .IFC. I click File, then Export but cant get any further than that. I dont know what else you want me to say?
Message 9 of 13
Alan.johnson1970
That sound right,
My export to ifc is not greyed out. (Revit LT 2017)
I know if you were in a schedule the export ifc option would be greyed out.
so you need to be in  either a 3D view or Plan
AJ.
Message 10 of 13
Alan.johnson1970
can you attach your .rfa, and i can try open and export to ifc.
AJ.
Message 11 of 13
Hi Alan, Thanks for your support! appreciate it. I have tried what you have suggested and unfortunately it hasn't worked, however I've made a quick drawing within Revit to test that and it has worked for that! so I think it must be something related to the file. I've attached the file.
Message 12 of 13
Alan.johnson1970
Load the .rfa into a project then export to ifc
AJ.
Message 13 of 13
RobDraw
Have you tried inserting the family into an actual project?
Rob
