Revit LT with A360 - Cannot view phases
shivraj.panaich
shivraj.panaich
I am trying to upload a model to show my client the proposed changes to his scheme. I am using Revit LT so do not have the advanced collaboration tab.
How is it possible to upload the rvt file to A360 so the client can view the project new construction phase. Currently only the existing phase is view-able and no other phase thereafter.
I appreciate any help possible.
Thanks in advance 🙂
Shiv.
Viveka_CD
Hi @shivraj.panaich
Which version of Revit LT are you using?
Can you export to dwg and share it on A360?
shivraj.panaich
Hi Viveka,
I got the help from the forums. It came down to the fact that Revit LT doesnt allow multiple exports of 3D views to A360.
I have to set the {3D} default view to the phase I wish to view on A360 and then upload the file. Which means that each phase of the project needs to be saved individually with 3D default view on chosen phases and then viewed individually.
Bit of a headache of a work around. If this was included within Revit LT as a "basic collaboration" rather than full Revit "advanced collaboration" that would be perfect.
Viveka_CD
Hi @shivraj.panaich
Thanks for getting back!
Regarding basic collaboration for Revit LT, you are welcome to post to the Revit ideas forum and gather votes for your idea to be implemented.
