Revit LT tutorial files
ckbillingham
795 Vistas
6 Respuestas
Mensaje 1 de 7
ckbillingham
I downloaded the free trial of Revit yesterday, the download and installation when on with no problems.
I then went to start the tutorial and download the zipped exercise files, located here: https://knowledge.autodesk.com/support/revit-lt/getting-started/caas/CloudHelp/cloudhelp/2015/ENU/Re...
The zipped file downloaded, I extracted the files and went to start. But the file for the first exercise "Part 1: Creating a Project and Adding Levels", is not there in the zipped folder; it looks like all of the other files are there.
Does any one have the first exercise file that can be posted somewhere?
Thank you!
0 Me gusta
796 Vistas
6 Respuestas
Respuestas (6)
Mensaje 2 de 7
dzanta
i do not have the exercise files but if you want to learn all about Revit and other Autodesk software:....
Autodesk Education Elite Page (Facebook):
https://www.facebook.com/groups/1091406907537312/
Autodesk Educational Work Videos (Facebook):
https://www.facebook.com/educationalworkvideos/
Facebook Profile:
https://www.facebook.com/dzanquocta
LinkedIn Profile:
https://www.linkedin.com/in/dzanquocta
Twitter:
https://twitter.com/DzanTa1
YouTube Channel:
https://www.youtube.com/channel/UCt51GI7E-wmrmuXw3kENDNg
Autodesk Knowledge Network:
https://knowledge.autodesk.com/profile/O37DF450ED825678
Autodesk Expert Elite (LinkedIn Group):
https://www.linkedin.com/groups/8404813
Autodesk Forums:
http://forums.autodesk.com/t5/user/viewprofilepage/user-id/490193
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
0 Me gusta
Mensaje 3 de 7
loboarch
First exercise is designed to start from a default architectural template.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
0 Me gusta
Mensaje 4 de 7
ckbillingham
Thank you! I missed that somehow in the instructions! That makes a lot more sense!
0 Me gusta
Mensaje 5 de 7
No aplicable
I just installed Revit LT 2015 on the computer and want to go thru the tutorials.  I followed the first tutorial because it did start with the architectural template but the 2nd one uses a file created by the program.  When I downloaded the tutorial files that I found online, the message said I can't use them because they were saved by a newer version.  Can you share with me a link to the 2015 tutorials or share a zipfile?  Thank you!
0 Me gusta
Mensaje 6 de 7
loboarch
If you are successful on the first lesson the tutorial is designed that you can keep going with the same file.  if you want the incremental datasets you can access them via the 2015 online help.
http://help.autodesk.com/view/RVTLT/2015/ENU/?guid=GUID-9E9688A2-0645-4F8E-9D96-F1B76291A6C6
2015 is no longer supported.  I would suggest using a newer version of the software if possible.
Jeff Hanson
Revit Help |
0 Me gusta
Mensaje 7 de 7
No aplicable
Thank you very much. I did not realize, but I understand about it not
being supported... unfortunately it's the only version I have available at
the time. Thank you again.
0 Me gusta
