Dear Revit Experts,
I found that my Section view on Revit drawing, when exported to AutoCAD (.dwg) format, is rotated and shifted. Anyone knows why? Is that a potential bug of exporting Revit drawing to ACAD?
The detail of what I am doing is as follow:
1) Set 1 - I create a family model (Fig. 1), the site origin of my model is (0,0,0). Then, in West Elevation, I create Section 1 (Fig. 2). The resulted Section 1 is shown in Fig. 3. Then, create Section 2 on Section 1 (Fig. 4). The resulted Section 2 is shown in Fig. 5. Then, all these are put in a drawing (Fig. 6). Then, it is exported to ACAD (Fig. 7). This resulted in some error in Section 2, in which it is rotated and shifted.
2) Set 2 - I import the family model into a project at (1000000,1000000) (Fig. 8). Then, I created some sections as before (Fig. 9). When exporting it to ACAD (Fig. 10), the resulted Section 2 is blank.
Why this happens? Is it because of: 1) Double section, 2) Shifting, 3) Potential bug? I am just guessing.
I really need your advice.
Best regards,
Clement
Gelöst! Gehe zur Lösung
Gelöst von www.TechRoom.bg. Gehe zur Lösung
I think this problem was fixed after 10' version but check:
For rotation check this:
I will try to make same sections but i think there's no problems with section stacking :?
I hope this will help you!
Eng. Iliev L. ![]()
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Dear Iliev,
Thank you for your reply.
The problem is, however, still persist when exporting to ACAD after unchecked the box.
Best regards,
Clement
This solution is not a solution. The problem still persists in Revit 2021 @Anonymous
