Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using Revit Lt 2017. I need to export files to pdf so I can email the file in pdf format. The PDF export is critical due to the fact that's what my clients need to do there part of the project. I'm also using autocad architecture 2013. ACA-2013 has an export to pdf function, which makes it easy to e-mail . Revit Lt does not. the revit program is better since I don't have to deal with the project navigator. otherwise I would use ACA-2013 Is there away attach pdf function for revit lt or another way to export Revit Lt to PDF.?
