dark toolbar
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
3529 Aufrufe, 11 Antworten
dark toolbar
when converting to dark scheme , only the tab titles get dark but all icons still gray?
why is that?
11 ANTWORTEN 11
Nachricht 2 von 12
RobDraw
als Antwort auf: Anonymous
@Anonymouswrote:
why is that?
Someone forgot what color to make them.
Rob
Nachricht 3 von 12
als Antwort auf: RobDraw
I have seen once in video tutorial, the Revit were in dark theme as other Autodesk programs
Nachricht 4 von 12
RobDraw
Incredible.
Rob
Nachricht 5 von 12
zhukoven
@Anonymous, here is a workaround that you could use to tweak the interface:
https://forums.autodesk.com/t5/revit-ideas/dark-theme/idc-p/7480326#M14989
Nachricht 6 von 12
als Antwort auf: zhukoven
@zhukoven many thanks for your replay, the post you shared have good idea but using magnify and invert color invert all colors in all programs
which is not required
why does autodesk don't want to add this feature although its used in the all other programs like max and autocad
Nachricht 7 von 12
zhukoven
@Anonymous, it's strange because you're able to change the ribbon colors via the Revit API:
http://thebuildingcoder.typepad.com/blog/2011/02/pimp-my-autocad-or-revit-ribbon.html
Note the date of this post: 2011 Smiley (fröhlich)
Nachricht 8 von 12
zhukoven
@Anonymous, you can also vote for this idea: https://forums.autodesk.com/t5/revit-ideas/full-dark-theme/idc-p/7893071
Nachricht 9 von 12
many thanks for your hard search and support
I vote for the idea have recommended to me
and I will study Jeremy's subject and I hope it help
but I think I have to redesign all the icons for the large and small types which is to bad and time waste
this is not the ideal solution and Autodesk should provide that as in all its products and I can consider your effort as accepted solution
many thanks
Nachricht 10 von 12
I have following the jermey's tutorial and it is very good
but I couldn't know how to change icons or fonts , types or size or color for icon's and titles
Nachricht 11 von 12
Why do you need to change them?
Nachricht 12 von 12
als Antwort auf: ToanDN
I don't want to change the text of them
all I need is to change the color & font to have some thing comfort my eyes
