Lumion.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
Autodesk Certified Professional
While I do not belive that Revit LT supports intallation of plugins for direct/live sync, you can alwas export your model as FBX, OBJ or SAT and then use that with most of the external rendering software available in the market. Previously I have used the following, nowadays not much, if I render anything it would just to mess around and find out what is new
Hi @vblevin
Thanks a lot for posting your question to the forums! Have the solutions suggested by @RDAOU @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Technical Marketing Manager | Construction
when you reload the FBX back into Twinmotion all the materials stay the same, as long as you didn't change them in Revit.
