Revit LT and Rendering Software
vblevin
vblevin
Has anyone used a rendering software that works with Revit LT exported files?
vitorbortoncello
Lumion.
https://support.lumion.com/hc/en-us/articles/360022038739-What-CAD-software-is-compatible-with-Lumio...
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
RDAOU
@vblevin
While I do not belive that Revit LT supports intallation of plugins for direct/live sync, you can alwas export your model as FBX, OBJ or SAT and then use that with most of the external rendering software available in the market. Previously I have used the following, nowadays not much, if I render anything it would just to mess around and find out what is new
  • Twinmotion
  • Lumion
  • Vray
  • Blender
handjonathan
Hi @vblevin
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @RDAOU @vitorbortoncello  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
vblevin
I'm using Twinmotion. It works great with Revit LT fbx file exports.
blank...
What happens when you change the design and reload the fbx in Twinmotion? Does it lose, materials, UVW mapping...
vblevin
when you reload the FBX back into Twinmotion all the materials stay the same, as long as you didn't change them in Revit.
