- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello
Been using Revit LT since 2012 and when I usually see this problem it show up on the 3D and can usually see the error of my ways.
This is a bit Different ....Staring out it worked just normal but as I go I get these Wall joins (see attached ) one by one
I use the join tool but the only fix is to miter the corners
The 3d and elevations are showing the corner properly
Its only the exterior walls and not interior.
One thought I had is.... I use a template that I build up on over the years so maybe it is not compatable with the 2016 version?
I started a new project without the template, and the walls are joining properly (clean) and I also copied and pasted the main floor into it and the walls are fine but i havent worked in the new project to see if over time I get the same results
Or is there a setting I dont know about ?
Thank you for all you help Its very much apreciated !!!
Wes
