Clayon, I've been in your shoes. It would help to know the discipline of the consultants you're using that are providing you with CAD that you need to dimension to. If it's MEP, I would question the need to dimension to anything at all that they provide. If it's civil, as you mentioned before, there are only a few things that you would need to be dimensioning to, and I would recommend recreating those items with either detail or model lines, as appropriate. If it's the structural model, which would be my guess, that you're concerned about, I would highly recommend recreating the structural design in your model. It may not be part of your original scope, but if you're already to the point in the project where you've got 300 sheets, then the ship has sailed on talking about it up front, as should have been done.
For the details, it's a bit of mixed bag. I would recommend live details wherever possible, because "standard" details tend to become not-so-standard-after-all when applied to an actual project condition. You can place a dummy sheet in the drawing index, and keep all those details in separate CAD files.
If you want to create a detail callout, referencing those CAD details, then you've got four options:
- Link each detail into a drafting view, then reference that view <-- Most Revit-y option, somewhat time-intensive depending on the number of details
- Create "dummy" drafting views and place them on a "dummy" sheet with the same numbering as shown on the CAD sheet <-- Semi-Revit-y option, fast option, most likely to have mistakes due to poor manual coordination
- Make a "fake" detail callout that looks like you're regular detail callout, but can be filled in manually with the detail reference data <-- Semi-Revit-y option, slightly faster than option 2 due to not needing to make lots of dummy placeholder details
- Recreate the details in Revit <-- Most Revit-y option, most accurate, and most time consuming
What you choose to do is dependent in large part on your particular project, particularly the number of and complexity of the details you have from CAD. What you'll likely end up doing is some combination of Options 3 and 4. It has a relatively high potential for errors, especially if there are to be any modifications to the CAD details at any point. You could also choose a few of the details (as many as possible) to convert to Revit. Prime candidates for this conversion are any CAD details that are not correct or otherwise need to be updated.
Hope that helps.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
