Revit Linked Model Does Not Show!
I can link in AutoCAD files perfectly fine i.e site plan, but when I try to link a building into the Revit Site Plan file, the building doesn't show up!
I have removed, re-tried. Not visible in any view, plan, section, 3D etc.
I can select the file as per the screen shot but nothing is showing!
Please help.
martijn_pater
Could be placed on a workset that's set to not be visible in views...
Already checked worksets and its on Workset 1 which is viewable in all views.
ennujozlagam
check your bulb icon it could be hidden in the view, or there is a view template assign > set to none? or check your phasing? or go VG > revit links and set to custom. thanks
It seems there may have been an issue with the original file and what was actually in it. I saved over it with my local copy to the server and re-created the Central Model of the Block/Building and it is now showing.
Mohamed-Nassar
look at workset or may this file have shared coordinates
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Go through this list of 33. Betcha one dollar one of them applies. 😉
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
