ODBC Export not including the Project Parameters
Harikrishnan.AK
Harikrishnan.AK
I am trying to export Revit Database as part of the data extraction initiative for analytics and stuff. This is the process I am currently following,
  1. Have setup an SQL Express Server in system (not cloud)
  2. Create a Database (in the Server Management Studio) for the Revit project that I will be running
  3. Create a ODBC Data source using "ODBC Data Sources 64-bit"
  4. Open Revit
  5. File -> Export -> ODBC -> Select Database -> export
  6. Setup a Power BI Dashboard to visualize data
I checked the columns of the "Instance" tables not the "Type" but couldn't find custom "Instance" parameters
Same issue with Type parameters as well. I couldn't find Custom "Type" Parameters.
Any help is much appreciated!!
lim.wendy
HI @Harikrishnan.AK ,
Welcome to the forum and thanks for posting. Can you check these threads as well as this to see if it helps? They're pretty old threads but hope it provides some guidance...
Let us know how it goes...
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
