Revit library appears empty
Hello, I've had this problem for a while now. Every time I try to add a component to my plan, the library is missing. I've reinstalled the software multipile times, downloaded seperate libraries, still it appears empty. It seems as if it does not read any of library contents that I have on my computer. I also could not find anyone with the same problem as me.
Has this happened to anyone else and does anyone have a solution for this?
ennujozlagam
check your file locations from options > set to necessary default. thanks
RobDraw
What kind of component?
How are you trying to add it?
What library are you looking in?
Rob
