Stair Railing Connection & Transition Problem
I am looking to create a simple railing transition where the rails should meet at flat level to each other.
Please have a look at the screenshot i created,  I adjusted the 'landing height adjustment' and manage to get SPOT B to looks right. But the problem appear again at SPOT A because the landing adjustment affected it as well.
How can I create both junction's connection to be same as SPOT B?
Please do help!! Thank you!
bin
Can you Tab select the top rail and edit the path?
Yes, but it can only change the length of the rail but not the height and connection..?
Are you trying to do a Gooseneck?  Or Simple?
