Revit levels issue
11 REPLIES 11
Message 1 of 12
MYS-AvishayV
523 Views, 11 Replies
Revit levels issue
Hi
Help!
Has anyone had this problem?
Revit create automatic alot of levels while I'm modeling, alot!
see picture..
Alot of rendom levels that not attach to nothing:
Tags (1)
11 REPLIES 11
Message 2 of 12
Revit does not create additional levels. Most likely you have placed several links, one per floor, and each link is showing its levels.
Message 3 of 12
BDMackey
in reply to: MYS-AvishayV
I often see this happen when someone is using the copy command, don't realize they selected the level and copied and/or pasted it with other elements.
This is why I have a Level Schedule on my start up view.  This way I can quickly see if they were created. Then go into a view with any of the Temporary Worksharing options open and hover over the Level to see who created it, the creator will never be Revit 🙂
Message 4 of 12
VAKNINARCH
Thank you all but this is not the reason
Message 5 of 12
syman2000
Are those level placed inside a group? When you copy the group, it will copy in multiple level.
Message 6 of 12
VAKNINARCH
in reply to: syman2000
NO
Message 7 of 12
syman2000
in reply to: VAKNINARCH
Share the model so we can take look and solve the issue quickly. We can keep guessing and you will get frustrated for not getting any answers you are looking for.
Message 8 of 12
jay_colcombe
I count 20 ish floors there so your not far off come could be dummy levels uses for aligning elements to - try cutting a section and posting the image as this will tell us what they relate to.
Jay Colcombe
Autodesk Certified Instructor
Message 9 of 12
VAKNINARCH
thanks you all !!!
Our BIM Manager will check it with the experts of Autodesk.
Message 10 of 12
MYS-AvishayV
thanks you all
Message 11 of 12
There are more experts here in the forums that at Autodesk offices. For sure. We work on projects. They do not.
Message 12 of 12
Someone accidentally copied the levels and it is not a big deal, just delete them.  Leave Autodesk technicians deal with real issue instead of trivial things like this.
Forma Design Contest
