Revit Legend not updating
Message 1 of 11
I'm trying to update a legend, it has louver families in it. It will not update, even if I create a new legend it still brings in the olds sizes of louvers and not the new sizes of louvers. Any suggestions?
@Anonymous,
john.vellek has edited your subject line for clarity: Legend not updating
Replies (10)
Message 2 of 11
Alfred.NESWADBA
may I ask which product you are speaking about?
Vanilla AutoCAD does not have any functionality with legends.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 11
john.vellek
Hi @Anonymous,
Are these legends blocks with attributes?  If so, try using ATTSYNC or BATTMAN to get them to update. If you are using a different type of object can you give more detail or attach a sample file?
John Vellek
Message 4 of 11
Thanks, what I did was save each family as a different one and re put them in.
Message 5 of 11
Alfred.NESWADBA
Also AutoCAD does not know anything about "families" ... which product are you using?
Because of "family" and "legend" I guess you landed in the wrong forum. The question is now which is the correct forum for your question.
- alfred -
Alfred NESWADBA
Message 6 of 11
It's a Revit louver family... Actually from Ruskin...
Message 7 of 11
Alfred.NESWADBA
Well, then let's see if someone can move this thread to the Revit forum >>>there<<<.
As here is the AutoCAD forum not very much people will be able to understand your question and give valid suggestions.
Good luck, - alfred -
Alfred NESWADBA
Message 8 of 11
Sahay_R
Are the old and new sizes in the same family?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 9 of 11
I just saved the family with a different name, changed the original louver for the one with the new name, when I re-inserted the new one into the schedule it came in with the correct size. But basically is was re-doing the legend.
Message 10 of 11
Sahay_R
If the changed family had the same name, it would have over-written the old family and updated the legend.
Rina Sahay
Message 11 of 11
I tried overwriting the Revit family at first. But it did not update, When I re-inserted the new louver size, the old size came in. This was a Revit family from Ruskin. Therefore I ended up creating six different families from the original family. Maybe it's just an awkward family. But nevertheless, I fixed it and I consider this closed...
