Revit Lables in a Titleblock
2 REPLIES 2
caseydalexander
216 Views, 2 Replies
I'm new to Revit and I'm creating a titleblock with labels (Project name, sheet name, etc.) so they will populate automatically  with the information according to what project the title block is being used in.  I'd like the labels to be in all caps on the titleblock but I can't seem to find a way to do this.  Is there a way to change the labels from Letter case to all capitol letters? Thanks!
2 REPLIES 2
in reply to: caseydalexander
Why can't you change the information (Project name, Sheet title, etc...) to uppercase?
Or are you saying that you want the actual information in sentence case but they need to show on the titleblock as UPPERCASE?
syman2000
One quickest way to change all sentence case to all cap is to use certain font. If you choose TECHNIC or TECHNICLITE or TECHNICBOLD, you should get all letter as caps.
As well you can use the REVIT_HEB_SHX as another method if you want to make small letter and cap letter to look the same.
Forma Design Contest
Technology Administrators
