Revit Join Elements Priority
RKS_PRECISION
RKS_PRECISION
Is there a list of priorities for Revit join elements behavior.
I mean I need to know what is the top element categories which cut lower categories, down to the bottom of list.
I made some tests i found (stronger > weaker) Floors > Columns > Beams > Walls
But i need to have a full list of joinable elements priorities, is there any ?
Given if the list existed, what would you do if you found it?
What are you referring to?
Almost sounds like you are talking about layer functions/priorities of compound-layered system families, but for the mention of Columns and Beams.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-M...
Or maybe you are talking about "Material For Model Behavior" - a property of Structural Columns and Structural Framing (e.g. Beams)?
Beam Family Properties | Revit | Autodesk Knowledge Network
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2023/ENU/Revit-S...
RKS_PRECISION
i am aiming to create an auto-join dynamo script, so i need to study the behavior of join and also i need to collect all the categories which are available for join.
The behavior of join which i mean is which element cuts the other, therefore i decide how to and when to switch join between elements based on the users requirements ?
Did i mad it clear?
And by the way, and if anyone has something to tell me about this dynamo script, i can't find a suitable python script to use for joining elements, any recommendations based on any experience in this issue?
hamzatariq70
I believe this post can help you.
Set Revit Join Order Automatically | LinkedIn
