revit is not launching after windows update. (Yes. I've tried EVERYTHING!)
Message 1 of 9
After windows update Revit 2018 does not launch no matter what.
The journal says it:
' 0:< Initial VM: Avail 134213239 MB, Used 16 MB, Peak 16; RAM: Avail 10906 MB, Used 56 MB, Peak 16
' 0:< GUI Resource Usage GDI: Avail 9999, Used 1, User: Used 3
'C 10-Feb-2019 21:37:56.700;   0:< started recording journal file
' Build: 20170223_1515(x64)
' Branch: RELEASE_2018_SHIP
Dim Jrn
Set Jrn = CrsJournalScript
'C 10-Feb-2019 21:37:56.700;   0:< ->desktop InitApplication
'C 10-Feb-2019 21:37:56.717;   0:< <-desktop InitApplication
'C 10-Feb-2019 21:37:56.717;   0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Metric Library=C:\ProgramData\Autodesk\RVT 2018\Libraries\Brazil\,Metric Detail Library=C:\ProgramData\Autodesk\RVT 2018\Libraries\Brazil\Itens de detalhe (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -43 -> 134213197 MB, Used +6 -> 23 MB, Peak +6 -> 23 MB; RAM: Avail -47 -> 10859 MB, Used +15 -> 72 MB, Peak +15 -> 72 MB
' 0:< GUI Resource Usage GDI: Avail 9983, Used 17, User: Used 33
'C 10-Feb-2019 21:37:57.580;   0:< License initialization complete
' 0:< License version: 18.5.4.1
' 0:< ::0:: Delta VM: Avail -172 -> 134213025 MB, Used +31 -> 54 MB, Peak +33 -> 57 MB; RAM: Avail -66 -> 10794 MB, Used +48 -> 120 MB, Peak +48 -> 120 MB
' 0:< GUI Resource Usage GDI: Avail 9983, Used 17, User: Used 57
' 0:< SystemSettings:
' 0:<                    4=multiCoreCharacteristic
' 0:<                 true=isDotNetInstalled
' 0:<    4.7.03190(461814)=dotNetInstalledVersionString
' 0:<                false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
'C 10-Feb-2019 21:37:57.803;   0:< Assertion failed: line 444 of Pipeline\DataIntegrity.cpp
' 0:< Exception occurred
'C 10-Feb-2019 21:37:57.806;   0:< ExceptionCode=0xe06d7363 ExceptionFlags=0x00000001 ExceptionAddress=00007FF9294E5549
' 0:< BC: 0,0,1
' 0:<   System (MB) [Available /  Total ]  [Revit Memory Usage (MB)   ]
' 0:< RAM Statistics:    10792 /    16275       122=InUse      123=Peak
' 0:< VM  Statistics: 134213025 / 134217727        53=InUse       57=Peak
' 0:< Unconverted MessageBox "Ocorreu um erro irrecuperável.  O programa será agora terminado.  Todos seus dados recentes foram salvos, portanto, não há necessidade de criar arquivos de recuperação."
' 0:< ::0:: Delta VM: Avail -51 -> 134212974 MB, Used 54 MB; RAM: Avail +6 -> 10801 MB, Used +2 -> 123 MB, Peak +2 -> 123 MB
' 0:< GUI Resource Usage GDI: Avail 9974, Used 26, User: Used 60
'C 10-Feb-2019 21:37:58.900;   0:< program terminated
I've tried:
- Reinstall all  c++ Libraries.
- Reinstall Revit.
- Downgrade Net. Framework (Maximum i could was 4.7)
- Redo Windows Updates.
- Undo Windows updates.
- Lots of solutions proposed in this forum for similar issues.
- Rename the license folder to generate it new again.
- Hot fixes from Autodesk.
What i didn't try:
Reinstall windows (And i don't really want it. If it Update again maybe i'll have the same problem...)
I don't know what to do anymore.
Thanks for anybody who spend a bit of time trying to help me... Haha
Replies (8)
Message 2 of 9
ennujozlagam
hello, you can try to refer to these LINK and LINK and see if helps. thanks
Message 3 of 9
Thanks for reply!
Yes. I've tried both
Run in compatibility mode (All versions), Turn off firewall and anti-virus while installing and running, empty temp folder, update video cards (Intel and nvidia). I've downloaded the whole software again...
I'm desperate... Haha
I've been trying to make this work for a week at least.
Message 4 of 9
ennujozlagam
Hello, sorry I can't help much the only option is to use restore point a specific date. Thanks
Message 5 of 9
edwin.prakoso
Can you run Revit when you log in to Windows as a different user?
Cheers,
Edwin Prakoso
Message 6 of 9
Thanks for reply!
I just tried to run revit using a different user. Still the same...
I think i will need to reboot my pc from 0....
Message 7 of 9
Viveka_CD
Hi @Anonymous
Sorry to hear that you are having issues.
I'm assuming you would have tried this, but a clean uninstall, re-install sometimes can resolve the issue.
Please see the below articles:
Add or Remove Revit Content
Perform a Clean Uninstall
I'm wondering if you get an error message when trying to open the programs? Does the issue occur with any other programs? Did you try uninstalling and reinstalling the third-party programs which are causing the issue?
I would suggest you try a clean boot
How to Perform a Clean Boot (Applies to Windows 10)
If nothing helps, please post a full journal and a data-set.
Please see AKN article: Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Looking forward to hearing from you.
Message 8 of 9
Check to see if Update 1809 was installed.  Have heard lots of people having issues with this one and if so, try uninstalling it.  Unfortunately, I know some folk have had to reinstall Windows after this update.
How Windows 10 was installed seems to really affect how this update wreaks havoc with Autodesk programs.  Workstations installed with 1803 seem to be immune, but older versions or those upgraded from 7 or 8 seem to not like the update.
So if you do have to reinstall Windows, get the latest DVD, not the one that came with the workstation.
Message 9 of 9
@Viveka_CD  @Anonymous
Thanks for reply.
I did it all step by step. I'll try to do as @Anonymous said. I'll surrender and reinstall windows using an updated media. I've entered in contact with my PC support and they will provide it for me.
Thanks a lot for your help!
