Revit is 2016 not opening
Licensing error 10 is occuring. Hence the revitt software is not opening.
ennujozlagam
hello, it could be your serial number is not correct. try to contact autodesk technical support. thanks
kittugs143
This problem might occur with your serial number try to uninstall the software and reinstall the product.
Go to this link: https://ava.autodesk.com/
Best regards,
G.Sivakrishna
Product Specialist - AEC
www.sivakrishna2013.weebly.com
If it solves your problem, feel free to click Accept Solution.
Viveka_CD
Hi @Anonymous
Please try a repair of Revit and let me know if you are able to launch the application.
Check if you have the latest updates installed for your Revit version.
Let me know if you have questions on the above.
