There are a couple of "ghost" stair runs that I'm not sure how to get rid of. To clarify, these runs do not belong to a stair (cannot delete) and my attempts to duplicate types and purge without rebuilding all of the existing assembled stairs has failed.
It's a bit confusing to explain so I am attaching a pared down model. The ghost stair will highlight when you hover over the clearly annotated area. The element ID is 14348496
Gelöst! Gehe zur Lösung
Gelöst von JordanBillingsley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I was able to delete it. Perhaps Auditing the file will fix the problem.
Curious...
Could you please send me the file back or take a screen snip (or cast would be even better)?
Unfortunately audit on the original file and pared down file has not helped on my end.
Thank you!
I'll see if the team can upgrade but for now I will keep the ticket open if anyone else wants to take a stab.
Thanks!
Wish Revit had an Explode command like AutoCAD. I would blow this thing to smithereens! It's irritating the heck out of me! ![]()
FWIW: I did get it to delete by deleting the Main Level. Obviously, not a viable solution -- but it felt good all the same. Booyah!
See attached file. Remnant run and landings were deleted from schedules.
