Revit installation issue
Having problem with installing the software.
See attached file.
N.Oomen
Hello @Anonymous,
When you read trough your log it says you have issues with downloading the material library 2016 and then it's starts a rollback of your software and you get some more errors with your visual basics installations.
I didnt receive an error code so can't help you on a specific item, but did find link below. Downloading the software from virtual agents seems to be the solution pretty often. But again I didn't receive a error code so it is one solution.
http://forums.autodesk.com/t5/installation-licensing/download-failed-installation-aborted-result-1603/td-p/4716025
I would really like to hear from you if this will solve your problem or you have any more questions.
For all other Forum members, it would be nice if you mark the reply as a “Solution” when it answers your question.
Good Luck,
Niels Oomen
Best regards,
Niels Oomen
Cadac Group BV
Sr Consultant AEC
