Revit insigth 360 plugin - solar analysis
0 REPLIES 0
Message 1 of 1
243 Views, 0 Replies
I am currently experiencing two errors in when using Revit's solar analysis.
First, the moment I set the solar parameters, I am getting this error:
hitting disable updater seems to fix this error.
But then, few minutes after I run the solar analysis I am getting an Revit.exe - Assert Failure and Revit stops working and closes. Does anyone know what is causing this problem and how to fix it?
Thanks for your help.
0 REPLIES 0
