- Mute
- Permalink
- Report
Hey guys, I just can't seem to figure this one out! I am creating a framed opening that I would like to tie ADA Clearances to. Attached I have an image of what I currently have in the properties. I have an approach type for Side 1 and Side 2. (Front Approach or Side Approach) For each of these options I have a different depth clearance. So below I have created a parameter for the depth of the ADA clearance depending on if it is a front or side approach. I would like these depths to adjust automatically when you select the check box above. I am trying to figure out how to do an if statement here with my yes/no parameters above. With the formula I have in the image below I get the error "Improper use of boolean expression". How do I set this expression up properly?!?
Thanks in advance! š
