Revit only shows Solid Blockout and no hatch
I am running Revit 2016 and whenever I create a Filled Region, it creates a solid white blockout.
I cannot get the hatch patterns i specify to show, only the white blockout that blocks out all imports, elements and catagories in my project.
I have checked visibility graphics and detail items is checked on aswell as all the boxes in the dropdown.
even if i create a new hatch pattern, the hatch pattern does not show.
Any ideas?
Are you using a Masking Region vs a Filled Region?
Filled Regions you can change the Type in the Properties window...Edit the Type to modify the Fill Pattern you want, whether it's a drafting,model or solid color.  A Masking region doesn't give you any options to change the pattern.
chrisplyler
First guess is you created a masking region instead of a filled region.
Second guess is that you've set the hatch fill to be solid white.
Third guess is that your view is set to such a tiny scale and made such a small filled regioin that you're only seeing a bit of white space between the lines of the hatch.
It shows both the filled region and masking region as the same element.
i have attached a picture of the example.
The top block is a masked region and the bottom block is a filled region.
the properties for the filled region are in the second pic.
The hatch type is not on solid white and the scale is 1:100.
This only appears in this current ,rvt file, if i open a new file, the hatching shows as normal again.
Thanks for all the replies.Smiley Happy
Rafal.Gaweda
Autodesk Support
Autodesk Support
I think it can be related to visibility filters in your file.
See below:
Rafal Gaweda
Thank you,
I knew it would be something simple
