Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Revit hidden family/Objects in certain views
cadedu22
cadedu22
Greetings,
Like I want to Load the family into Revit, but in only one "View", I don't want it to appear in every view/sheet?
Otherwise, I'm loading Family and need to sort every page and "Hidde" it.
rxi.gg
You can not do that. A loaded family will be seen by default in all viewports. What occurs to me is that you create a Workset for these families and only show it in the viewports that interest you.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
You can create a Detail family to get that behavior.
jvpantin2
Hi, @cadedu22, by its own nature, all model families -as any model element- are visible in all views, depending on V/G settings. Only annotation elements and families -like Detail items, as @ToanDN said- are visible in the specific view were created or placed.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
cadedu22
@jvpantin2 @ToanDN @rxi.gg
Thank you for answers, in this case, "Workset" solution works.
