Hi All,
Has anyone come across a hatch pattern that can symbolize vertical timber boarding which is at unequal widths? say one board 100mm width another 55mm wide and the another 250mm wide etc...
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von Pattycake_Kyle. Gehe zur Lösung
in which case you might find HatchKit for RevitLT handy but possibly overkill for a pattern containing only vertical lines giving widths of say, 100, 55, 250, 45 repeating indefinitely:
; Written by HatchKit for Revit LT
; HatchKit for Revit LT (c)1990-2019 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2019-03-26
;-Time : 10:36:22
;-HatchKit Version : 3.1.11.2774
;%VERSION=3.0
;%UNITS=MM
*TimberBoarding
;%TYPE=MODEL
90,100,0,0,450
90,155,0,0,450
90,405,0,0,450
90,450,0,0,450
hth,
Hugh Adamson
@stuart Something like this?
Download or further adjust the PAT from here: https://pattycake.io/pat/22doryzwoll
Quickly laid out a bunch of random vertical board widths and just random lines across - apologies for the random numbers, but maybe this is what you were thinking about. I did it with imperial, but you can flip from inches to mm and then use a global scale factor of 2.54 or 25.4 depending on your units.
Made with Pattycake - a web based, real-time PAT editor which requires no plug-ins or software to download.
Hugh thanks for this.
Also thanks for the head up on hatchkit. Will check it out
