How to cut floor's geometry intercepting with roof
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
418 Aufrufe, 2 Antworten
Picture one is what I have. Picture 2 is what I want to follow.
2 ANTWORTEN 2
Nachricht 2 von 3
nicholas_seibert
als Antwort auf: Anonymous
Join should work.  Go to the Modify tab, and in the Geometry panel look for Join.  Select the roof, then the floor. Hope the helps.
Thanks!
Nicholas Seibert
Principal Revit QA
Nachricht 3 von 3
I think it's a combination of Join Geometry, as @nicholas_seibert mentions, plus Cut Geometry to cut back the eave.  You can do this by drawing a Ref. Plane in Section View that aligns with edge of floor, and then using the Cut Geometry tool to cut back the roof to this Ref. Plane.   Then Join Geometry.
...or, just edit Roof Sketch to adjust the overhang.
