Revit functionality - Functionality gone from 2019
gabbi
gabbi
Good day,
Can someone please assist with this query from a client:
Regarding the way forward with Revit, they used to use the functionality under the extension which was the modelling tab which is not in the 2019 version of Revit but was in 2018. they would like to know what is going to be done as there is no work around for this and they used to use it extensively to do their modelling. Will that functionality be reintroduced in the 2020?
Thank you
Kind Regards
Gabbi
RobDraw
@gabbi wrote:
Good day,
Thank you
Kind Regards
Gabbi
Your explanation of what is missing is really hard to follow. My best guess is that either they didn't install the extension or if it is a native Revit function, they simply cannot find it.
Please post a screen shot(s) of what they used to use.
Rob
I think you are talking about REX 2018.  No longer available.
Thought I was reading a script from Clerks but about Extensions vs a Movie....
@Anonymous : question: was it thirty-six or thirty-seven? Still unclear on that one.  he,he.
gabbi
Thanks so much. Apologies, new to the forums so just regurgitated what the client said to me.
Appreciate all the responses.
No Worries. My last remark was to @Anonymous, not you.
I think you are talking about REX2018,  It's no longer available.  But, with Previous Rights Versions, who could still use in 2017 or 2018 and then load into 2019.  But, the bottom line is:. it's just a fancy, schmancy Curtain Wall or Beam system.
