comment créer des claustras,mur evidé en façade ou mur en double peau,moucharabiah,...
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
you can use a Curtain Wall with Fixed Distance so to fit a fixed Curtain Wall Panel into it
Constantin Stroescu
Mr.Barthbradley ,before sending a détail ,i ' m wondering if it's possible to export to revit architecture 2018 ,what i have in mind (moucharabiah) this claustra work on Architectural autodesk autocad version 2014 .
Are you asking if you can IMPORT into Revit something that you did in AutoCAD -- and then use it as is in Revit? Well, that depends, but generally you what to recreate CAD work using Revit elements. You could certainly import your CAD into Revit and use it as a guide, and then delete it afterwards.
Post your AutoCAD file. Let's take a look at it.
