Revit Freezing
Revit Freezing
andrewrider
Revit Freezing
andrewrider
Lately I have had a few users experiencing a strange freeze up in Revit 2016. It appears that Revit has locked up and the only thing you can click or access is the R in the top left of the screen. From there we are able to close the files which will prompt us to sync our files. But there is no error generated. Just wondering if anyone else has experienced this and if there is any solution for this behavior. Again I have only seen this with the Revit 2016 version so far.
maybe you r working with big file size, you have hardwere problem, vga card, processor , network problems in wires or router
i was working on workstation and revit was hangs some times , when i change the computer with i7 processor and 16 giga ram it works will now
some workstations causes problems to revit
andrewrider
Not sure what is causing it but like i mentioned its not a total freeze. Revit still responds but only by clicking on the R file menu. I don't believe file size has anything to do with this.
divide your elements on some worksets and put each link in your file to separated workset then close the worksets you don't need
this may help in speed up the navigation and may help revit not to freeze
ennujozlagam
@andrewrider hello, have you try to install latest updates from autodesk and see if helps. thanks
