Revit formula with multiple conditions - How to write
Jessicas
Message 1 of 11
Jessicas
HI,
I have a family i'm creating and there's a nested item that needs to be visible under certain circumstances.
Its a U-Shaped family, the sides are visibly controlled by yes/no parameters
There's a centre support that needs to be visible if the length gets to 8' or above.
So this is what I the conditions need to be...
Centre support visible if Length_Main > 7'11"
but if the Left side is visible the necessary length would be 7'11 + 1'4"
if the Right side is visible length would also be 7'11 + 1'4"
if Both sides are visible length would be 7'11" + 2'8"
does anyone know how this would be written. I'm definitely not good with writing the formulas.
Thanks in advance if anyone can show me how the formula would look.
Replies (10)
Message 2 of 11
Please share the family file.
Message 3 of 11
Alfredo_Medina
You need to build a formula that checks for those things in order, from left to right, like this:
  • first, check if Left is visible and Right is not.
  • If that is true, do this,
  • if not
  • check if Right is visible and Left is not,
  • if that is true, do this,
  • if not,
  • check if both Left and Right are visible
  • if not,
  • use a default or base length.
That sequence, translated to a formula, is like this:
Message 4 of 11
My shot at it.  See if I am missing any conditions.
Message 5 of 11
Jessicas
Sorry I was able to post this right at the end of my work day.
Message 6 of 11
Jessicas
Can anyone help with this? I've tried quite a few times to get something but i always get errors.
Message 7 of 11
Have you tried the formula provided by @Alfredo_Medina and the other one by myself?
Message 8 of 11
Jessicas
I tried Alfredo's it seems more towards what i think i need. I tried so many things with it and couldnt get anything to work.
Yours.... honestly i have to idea whats going on 😮 really truely i suck at formula stuff
I attached the family in an earlier reply maybe it will help if people see the actual family set up.
Message 9 of 11
We use different approaches to reach the same goal.  @Alfredo_Medina created one complex formula that does it all where as I decided to break it apart.  I showed screenshots of multiple conditions so you could see how the formula works.  It's up to you which one you select.
Message 10 of 11
Jessicas
ok. Well I've had to move on so once I get back to that family I'll try your version out and see if i can get it to work.
Message 11 of 11
Here is my attempt at your family.  Obviously my brain is not as good as @Alfredo_Medina so I needed to add a few more parameters in order to make it work.  His original proposal should work if you can digest it.
