Drop Down menus in properties panel will not display.
7 ANTWORTEN 7
Nachricht 1 von 8
913 Aufrufe, 7 Antworten
When I try to open any of the drop down menus on the properties panel, they do not drop. For example, if I want to change the base level of a wall via the drop down menu on the levels part of the properties panel, it wont drop. I will just keep clicking it, but nothing will drop down, nothing will happen.
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Do you mean this?
Nachricht 3 von 8
als Antwort auf: ToanDN
Yes, however when I click on the drop arrow, nothing appears, nothing drops. I can type, say for example certain floors, but the convince of the drop down menu will not show.
Nachricht 4 von 8
Try:
- Cycle hardware acceleration On and OFF
- If you have a 4K screen and/or have the Display Scaling set to something above 100% then set it to 100%.
- Run a Repair installation
Nachricht 5 von 8
I have tried all of those options, and none of them seem to be working
Nachricht 6 von 8
Well then I guess a complete un-install / clean re-install is in order.
Nachricht 7 von 8
I have also done that
Nachricht 8 von 8
jmaguireND7GZ
Any updates on a resolution?
