Constrains windows to beign door window
I have constrain as attachment 1 and not like 2.
Only usefull constraiun I have is Heat Height (dim between top windows and floor level)
Why?
Thank's
Sahay_R
In your model, select the window. Click on Edit Family. This will take you to the Family Editor
In the Family Editor, click on this
This will take you to Family Types. You can add required parameters in this.
You create parameters by clicking on this
In your case - Window 1 has different parameters from Window 2. That's all.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
