Revit families exported from inventor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have the following situation: I export an aluminium pressing from inventor as a revit generic family; in revit, I assign a material(with a cut pattern) to this object; when I make a section through this pressing, the cut pattern doesn't work (only the contour line of the object is visible). If I use this material for a revit object (beam, column, wall, anything), the cut pattern works.
Can anyone advise how can i make the cut pattern to work on element impirted from inventor?
Kind regards
Petru
