I am trying to create a model in place component,extrusion, but every time i click the check box it gives me a error. Does anybody know how to fix this?
It happens, doc. Double-check and make sure no line segment is less than 1/32".
...also check for overlapping lines.
have a look at this zoomed image of your drawing. You can see that there are areas of self intersection or tangent that is not allowed....
Constantin Stroescu
Constantin Stroescu
Workflow:
1. Google searched and found "medic+snake+3ds+sketch.skp" (Sketchup).
2. Imported it into AutoCAD using the ImportSKP Add-In.
3. Imported this AutoCAD drawing into Revit Generic Model Template.
4. In Plan View, started Extrusion command and in Sketch mode I used Pick Lines + Tab key to select multiple line segments at a time. Pretty quick and painless.
I could have also just Imported the SKP directly into the Revit Family environment, saved the Family and called it a day.
Comme ci, comme ça.
Workflow:
Comme ci, comme ça.
