Revit Export to DGN Fatal Errors out
Message 1 of 12
In Revit 2017.2.3 everytime you click Export->DGN and click the seed file tab and check the "Use DGN Seed file for export:" box Revit has a Fatal error and asks for a recovery file. It has that behavior in a new (nothing in it) file, a sample file, a real project file.
I get DGN is not where we want to go but it is a submission requirement, so I have to export my final model and drawings out. Any other people have the same issue?
Replies (11)
Message 2 of 12
L.Maas
I only have Revit 2018 available. No problems there.
Check your journal files and see if something is in there that mention possible problems.
Other add-ins are also a common source for errors, so consider uninstalling them
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 12
It does exactly the same thing in 2018.2. Export -> DGN -> Check the box for Use DGN Seed file for export. Click the three dots to browse watch the blue wheel of death and boom! fatal error!
Message 4 of 12
L.Maas
Did you manage to check your journal file?
I have no problem selecting the ...
Louis
Message 5 of 12
nothing in the journal file its says "An unrecoverable error has occurred"
When it breaks on a blank file with no other actions don on it the issue has to be somewhere else. Two different version of Revit both fully updated on a fully updated windows 10 machine.
I can't even copy and paste in a path into the field which would be an annoying but palatable work around.
10-Jan-2018 07:57:09.202; 1:< logging finished virtualization services
'C 10-Jan-2018 07:57:09.202; 1:< logging finished worker services
'C 10-Jan-2018 07:57:09.202; 1:< logging erased queues
' 0.884583 1:<<<Terminating Slave Processes
' 0:< Unconverted MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
' 0:< ::62:: Delta VM: Avail -13 -> 134181918 MB, Used +0 -> 938 MB; RAM: Avail -132 -> 25200 MB, Used 968 MB
' 0:< GUI Resource Usage GDI: Avail 8906, Used 1094, User: Used 579
'E 10-Jan-2018 07:58:39.579; 0:<
Jrn.AddInEvent "AddInJournaling" , "MessageBox(OK,Revit).Click(Cancel)"
'H 10-Jan-2018 07:58:39.585; 0:<
Jrn.Data "MessageBox" _
, "IDOK", "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
'C 10-Jan-2018 07:58:39.585; 0:< program terminated
Message 6 of 12
L.Maas
I do not see clear indications what the cause might be, only generic error
' 0:< Exception occurred
'C 10-Jan-2018 07:57:08.313;   0:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=00007FFFB38C2F55
This would require some troubleshooting.
-Has something changed since the last successful export to DGN?
-Have you restarted your computer since problem occurred?
-Enough Free space on your drive?
-Try cleaning your Temp files (%TEMP%)
-Check if you have the folder as seen in my screenshot (C:\Program Files\Autodesk\Revit 2018\ACADInterop\)
-Do you have (dgn) files in those folders?
-Do you have read & write permissions to those folders?
-Try to switch of firewalls & virus scanners for a short time.
-Try to do a repair on your Revit installation.
-If it worked recently you could try to go to a previous windows restore point.
-Consider reinstalling your Revit installation.
Louis
Message 7 of 12
This isn't a just my machine problem -- this is an every computer on the network problem. Thanks for your help, we are working with Autodesk.
Message 8 of 12
L.Maas
Can you post the cause and solution when you have worked it out with Autodesk?
I (and probably others) am interested to know what happened and how to solve it.
Louis
Message 9 of 12
Viveka_CD
Hi @Anonymous
Can you post the case number? I can check back for details.
Also, see parent topic: Exporting to DGN
Message 10 of 12
I have the following case number 1377255513772555> from an email. I haven’t seen an update. Any information would be great!
13772555>
Message 11 of 12
Viveka_CD
Hi @Anonymous
The case status is open.
Updating to Revit 2017.2.3 was suggested, and I see that you've posted your journal, awaiting any further updates from the team.
Message 12 of 12
I am on 2017.2.3 with no luck. Thanks for the update!
